LOOKS LIKE THE FRONT COVER MUST BE REMOVED SOMEHOW!
Hi Stephen, Keep in the fore front of your mind that the steering wheel is fitted with an explosive air bag. The center piece of the steering wheel is removed by removing the fixing screws rom behind the steering wheel. Once those have been removed, disconnect the electrical connections by unplugging and place the unit aside. Behind that is the fixing nut holding the steering wheel. Loosen it and then using a puller remove the steering wheel. Behind the steering wheel is a special cassette which contains a special wiring loom which must be realigned correctly if removed or if a new unit is fitted. Failure to align it will result in it being broken or damaged. Reassembly is opposite. Regards John
Testimonial: "Thanks for the help. would you happen to know what wires are for the air bag. there are two plug in connections, one yellow with 2 wires the other black with multiple wires.Also which would be the horn wires. Thanks"
Off hand I don't know the identification of those cables, but you would be well advised to discconnect all cables. Th
Sorry about that, I'm answering you on my phone and sometimes it goes off half cocked. The cables in the cassette are not repairable, meaning if that if that is the reason for removing the steering wheel, you'll need to get a replacement unit Stephen. Regards John
3. Remove retaining ring. If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
4. Remove wheel bearing with suitable tool.
• Do not remove dust cover unless necessary. • Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
• Do not remove wheel hub bolt unless necessary. • Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
Assembly 1. Press in new wheel studs. Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
• Use a new oil seal, and apply grease to seal. • Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
