Question about Garmin GPS
Nuvi 855T locks up 10-15 seconds after power up
When I power up my Nuvi 855T and attempt to navigate screens, the user input is frozen after a period of time. Resetting the unit and clearing user data has no effect. Performing a software update [I've tried 4.20, 4.30 and 4.50] has no effect. What screens I happen to navigate to has no effect. If I don't enter anything and wait, it'll lock up.
I was hoping to perform a diagnostic on it to see if it is trying to talk to some broken peripheral but don't know how of if the unit supports diagnostics.
Email correspondence from Garmin tech support:
"Thank you for contacting Garmin International. We had an announcement
today that there will be a software update to address this issue coming
out within the next week. This is an issue we have found to be affecting
a large amount of 885 and 855 units. Please try the WebUpdater again
after next Tuesday to see if the update has been released. With the
update, your unit will be back to normal. Please let me know if there is
anything else I may assist you with."
I think the solution is obvious: Return the Nuvi 855T and get my money back.
Posted on Jun 25, 2009
Anonymous
SOURCE:
Garmin Nuvi 1390 says not enough memory
Nuvi 1390TFrom Factory Reset Jump to: navigation, search
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touchscreen when this message displays
  7. Touch Yes
    Found this for you on another site hope it helps...resetting the device should clear up your memory so you can download your maps...
Jun 09, 2012 | Garmin Nuvi 1390 With Dash Mount -...
If I found a garmin nuvi gps it got a locked on it how can I reset it or something
Most GPS navigation devices from Garmin has a reset function which allows user to access a Maintenance Mode screen with system information, diagnostic details or perform the reset function to restore Garmin Nuvi or other series unit to its original default factory settings.
Depending on which model of Garmin GPS unit you're using, the following routine can reset the Garmin device to original factory loaded settings, or bring up the Maintenance Mode with access to System Information and View Diagnostics screen, where users can see various logs, and of course, clear all user data (reset to factory defaults) or clear Waypoints.
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Hack above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Trick above works on Garmin nuvi 200, 250, 360 750, 760 series unit. In fact, there is a video demo by user of Garmin Nuvi 360 on how to perform the hidden reset function.
Hope helps. (remember to rate and comment this answer).
May 19, 2011 | Garmin nuvi 255W GPS Receiver
My Nuvi 265w screen is frozen
Hello Mark,
try giving the unit a hard reset, this is done by powering the unit off if you unable to turn it off let the power die out. when the unit is off place your thumb in the bottom right corner of the screen then power it on, do not remove your thumb untill the message " Are you sure you want to erase all user data " appears.
Hope this helps!
Dec 09, 2010 | Garmin nuvi 265 Car GPS Receiver
Garmin Nuvi will not load maps - why
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 885T keeps turning off during navigation. Not sure how to perform a hard/factory reset on the unit.
There are two solutions to get your Garmin Nuvi 885T running smoothly again. I have posted detailed directions in the Tips section of this Fixya website. Follow these two links to find step by step instructions on how to perform both the hard reset and the software upgrade.
I hope that helps.
Nov 25, 2009 | Garmin nuvi 885T GPS Receiver
I have a Garmin 396 that I use for aviation navigation. The 396 just suddenly became unable to find the satelites and therefore will not function. I tried to rebook by unplugging the battery for a couple...
I recommend either resetting the device or update the software. You can find software downloDepending on which model of Garmin GPS unit you’re using, thefollowing routine can reset the Garmin device to original factoryloaded settings, or bring up the Maintenance Mode with access to SystemInformation and View Diagnostics screen, where users can see variouslogs, and of course, clear all user data (reset to factory defaults) orclear Waypoints.
Power off Garmin unit. Press on continuously the uppertop left corner of screen and then power on the unit by pressing onceon the Power button. You should be prompted to clear all user data, orasked if do you really want to start up in maintenance mode. Press“Yes” to reset (warning: all data will be erased and lost,so backup before proceeding) or enter maintenance mode.
Turn off Garmin device. Press down on bottom rightcorner of the touchscreen, and then power on the GPS unit. You shouldbe prompted whether do you really want to erase all user data, or askedif do you really want to start up in maintenance mode. Press“Yes” to reset (warning: all data will be erased and lost,so backup before proceeding) or enter maintenance mode.
Trick above works on Garmin nuvi 200, 250, 360 750, 760 series unit.In fact, there is a video demo by user of Garmin Nuvi 360 on how toperform the hidden reset function.
Note: If entering maintenance mode, it’s also possible to perform master reset by selecting clear user data option.
Once the device has been hard reset, user have to perform the set upprocedure again upon start up. Note that erase user data command onlydelete data in the Garmin unit’s memory that isn’taccessible to the user when the unit is connected to computer. Thecommand does not erase .gpi or .gpx files loaded (if your .gpx filescontain any waypoints then they will automatically be imported intoFavorites), nor will delete any MP3 music, JPG photos or any otherfiles that have been stored on the GPS memory card.
Once the Garmin GPS unit is reseted, remember to place the deviceoutside where there is a clear unobstructed view of the sky for 15– 30 minutes in order for it to requires fix to GPS satellites.
Unfortunately, even if you perform master reset on Garmin GPS unit,it does not reset Garmin Lock security feature, which password-protectmost Garmin electronic devices to deter theft. If you forget the PIN orpassword unlock code to unlock the Garmin unit, the best solution is tobring it to Garmin to get unlocked. “Secure Location” doesnot unlock a locked Garmin unit either as it’s only a temporaryfix as when it’s turn on outside the security location, thedevice is locked again.
ads on the manufacture's website.
Nov 15, 2009 | GPS
I have a nuvi 205w I bought it used and reset it now I need to enter a pin number I don't know.
Have you tried clearing the user settings which is slightly different to resetting the unit?
I'm assuming that because you havnt got past the password screen yet you dont have any of your own settings on there yet?
Try this:
Hold your finger on the lower-right of the Nuvi screen while you turn the unit on.
Keep your finger pressed until the pop-up screen appears.
Touch YES to clear all user data.
** All original settings will be restored **
*** Any user items that you have saved will be erased ***
I hope that helps..
Mike
Sep 01, 2009 | Garmin nuvi 205W GPS Receiver
Garmin 660 locked up / frozen
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
May 09, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
281 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
