We have Kenmore super capacity 3.5 Quiet Tumble Action Washer
(970-045092-00)
We have not changed any of our washing habits or detergents - but everything works great until the final spin - it sometimes does not spin enough to get the water out of the clothes. They are sometimes sopping wet. We've tried the extra spin but it will stop well before the 13 minutes are up. Is there any filter that needs to be unclogged - or what???? - it's troublesome/ Thanks
You can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
everything is possible. you would hope he wouldn't do that. my wife screams at me every time i leave tools, pens, etc. in my pockets before she washes my clothes. you might have got something else transfered from your pockets into drain pump again. i would check your self before calling for tech
take out quarter inch screws at the bottom of the access panel. (bottom front) panel will remove with slight tug. drain pump should be right there in front kind of towards the right hand side. unscrew the cap. watch for water coming out. grab a towel before you take out coin trap
We had the sears repairman out a month ago to get a paper clips that had got down to the impeller - no damage - just noise when draining - Is it possible he moved something else there???
Is it easy to get to??? - any diagrams to know where I should check? - thanks
Did the solution work to look in the coin trap? I have taken the panel off and squeezed the black reservoir in front of the pump but do not feel anything blocking the pump. This only happens on occasion and like you, the spin cycle quits well before it should. If this solution did not work, what did you find that worked?
