Have you checked the throttle is returning to tickover on the carb ? cable sticking ?
If it is on tickover and still high reving then you could have an air leak after the carb , check the intake manifold , crank seals could be worn and this will let the engine rev by its self ! fuel mixture correct as if its 2stroke a lean mix can do this as well ! ??
