How can I enable Wifi on my Lenovo T410S
SOURCE: WiFi Keeps connection keeps switching off.
go to my computer propetes then go to hardware then device manager then network adapter enable if it is disabled
SOURCE: Wifi driver of Lenovo Y410
Here is the link for Intel....you will need to know the model #
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17227
and here is the link for vista drivers at Lenovo
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=6
I hope this helped...if so please rate me ...thanks ..The Fang
SOURCE: I have a Lenovo Y430 notebook and it was working
After making sure that the status of network adapters in the device manager showed enabled, I tried using the Fn+F5 key on my keypad. The Fn+F5 key showed my WiFi status as disabled inspite of the Wifi toggle switch on the front of the laptop in the "on" position. So I enabled it and the WiFi led started glowing and I was able to access the internet through WiFi connection
SOURCE: lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: problem with the wifi lenovo G450
Be sure your wireless switch is on. Then check your device manager. If it has yellow mark under network adapters, then you need to download driver for that. Click here to download driver. If that won't still work, try uninstalling Lenovo Readycomm from the list of your programs in Control panel. If that still doesn't work, contact your service provider to configure the wireless settings of your pc and router.
