When attempting to boot my Compaq Presario S4200NX, after pressing the Power button, the Compaq Splash screen is displayed followed by a single continuous beep and it will remain like this until powered off.
Maybe the hard drive is bad?
Most Compaq desktop that exhibits 1 long never ending beep indicates
Memory error; Bad RAM. Corrective measure therefore would be replace
and test.
You can try removing the memory and cleaning the gold pins
with a pencil eraser and try again. If this doesn't work, guess you're
back to replacing.
Good luck and kind regards.
when the power is turned on, it displays the flash screen,and attempts to start up, but then this continuous beep starts. I tried changing the memory already, did not help.Could it maybe be in the processor.
when i power my pc on it gives a continuous beep and displays only compaq and f1=setup f10=system recovery on the screen. i also notice that the speed of the cpu fan drops a little before the continuous beep begins
I have the same beeping problem and the F2 and F10 button is on the
monitor but both functions did not respond. I tried replacing the video card, mouse, keyboard, and still no luck. The fan speed also decreased.
