How do you force clearing the print queue
SOURCE: HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
SOURCE: Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
SOURCE: Document in queue won't print.
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
SOURCE: Seem to have a document
U have to clean the Print Spooler. What is Ur operating system? For example. in Windows 7 U have to: 1. Start > Control Panel > Administrative Tools > Computer Manager. 2. Select Services and Applications > Services. 3. In column Services seek for Printer Spooler and select it with the mouse. 4. Click right mouse button and select Restart. It should solve the problem.
To delete print jobs
stuck in the print queue on Windows:
If print job(s) still remain in
the queue even after doing the steps above: Clear the SPOOL
folder Try to print
again after clearing the print queue.
Stop the Print Spooler service from
the Services console
Start the Print Spooler service from
