Sounds like either a blown main power fuse or power transformer. If the fuse is blown it probably means a short in the amp somewhere. If it is the transformer, it can be replaced - but may cost more than the unit did.
CHECK THE FUSE BOTH IN THE CAR AND THE AMP AS WELL. IF THEY ARE FINE CHECK THE POWER SUPPLY WIRING. IF THE FUSE AND THE WIRING ARE FINE THEN TAKE IT TO A GOOD TECHNICIAN. REGARDS. PLZ. RATE THIS
You can download the installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) and download the drivers and software from the next page which opens.
Hope this solves your problem. Thanks for using FixYa.
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
