SOURCE: I have a Black and Decker 7.2 V cordless drill
Center pin is generally positive - outer ring is negative. But you can use a 9v charger just as easily; in fact, the one supplied with the cordless drill is a 9.0v, 200mA output charger.
SOURCE: Have a Fire Storm place battery in charger green
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
SOURCE: what is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
