Dell Latitude E6400 Laptop Logo
A
Anonymous Posted on May 22, 2014
Dell rcd msi download
Need DELLRCD.MSI file
DNA Computing!!!
Level 2:
  • Expert 304 Answers
  • Posted on Feb 19, 2015
DNA Computing!!!
Expert
Level 2:
Answers
304
Questions
0
Helped
91168
Points
728
You may download the DELLRCD.MSI file from the below link:
ftp://ftp.spez.com.ua/driver/notebook/dell/dell_1310_XP/INSTALL/DELLRCD.MSI
Hope this helps..
2 Related Answers
Anonymous
  • 700 Answers
  • Posted on Apr 24, 2009
SOURCE: I cannot download or open any msi file type.
It just, no application can open that file so windows is suggesting to search for application to open/run that kind of files. Say example you have pdf file and you don't have adobe reader or application that can open pdf format it will flag that kind of message for you to be able to view/run it.
Hope it helps.
Anonymous
  • 64 Answers
  • Posted on Feb 16, 2010
SOURCE: comunication software component are missing keeps
For most of my customers, this software is completely useless. If this is the case for you, I would recommend removing it from the list of startup items.
To do this:
1. on xp, click start, run, and type msconfig
on vista or windows 7, click start and type msconfig in the search box, clicking alow when the UAC window appears.
2. click on the startup tab
3. Locate the Dell communication program on the list (or all dell programs as I normally do) and uncheck the box
4. click Apply, then click done. The computer will prompt for restart.
5. After restarting on XP, a window will appear. Click the check box and click close.
Best of luck;
//halfs
Download rcd msi
I suspect you are using a Dell computer. The RCD.msi is Dell's Resource CD installation program. I'd recommend that you contact Dell on how to proceed.
3answers
I have windows 7-64 biti end i need this drivers.thank you----my motherboard is---K9VGM-V
You need to go to MSI's website and get the drivers from their support link for that particular motherboard.
http://www.msi.com/product/mb/K9VGM-V.html#/?div=Download
22helpful
I need msi ms 7061 motherboard drivers, vga driver and sound driver
For windows xp you can use the following links to down load drivers
1. Lan card -- http://download1.msi.com/files/downloads/dvr_exe/VIA_LAN100_71.zip
2. Sound driver -- http://download1.msi.com/files/downloads/dvr_exe/Realtek_AC97_MB.zip
3. Vga driver -- http://download1.msi.com/files/downloads/dvr_exe/KM400_73.zip
4. Chip set driver -- http://download1.msi.com/files/downloads/dvr_exe/VIA4in1_MB.zip
3helpful
2answers
How can i get driver sound MSi-ms 7529 version 1.6?
here: www.realtek.com/downloads, and choose High Definition Audio Codecs (Software).
194helpful
7answers
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
I refurbish cptrs for needy & received a Dell PPL or CPiA laptop. Went to Dell and downloaded *.app driver files but don't know how to make *.app work as a driver. Ideas? Oh- Can't get Dell techs to...
It is very simple. Usually drivers comes in the .ZIP, .RAR, .MSI or .EXE formats. Download the drivers in any folder. Then download the winrar software and extract the program at another place. You will find setup.exe or install.exe or similar file to execute. Execute the file and i will do everything automatically. But this will work only with any version of microsoft windows. For MSI or EXE files, just douuble click on their icon and they will do it for you. :-) ([email protected])
1helpful
2answers
Everytime I try to download certain software that uses MSI, I get this message. "Windows has the following information about this file type. This page will help you find software needed to open your
Hi Princess Tina,
It sounds like the registry keys needed to recognise and open msi files are missing or incorrect.
Paste the following into a new file (eg. with notepad) and save the file with a .reg extension. setupmsi.reg will do ok. Then double click on the saved reg file and add the keys to your registry. (The first line "Windows Registry Editor Version 5.0" must be the first line in the file).
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.msi]
@="Msi.Package"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package]
"EditFlags"=hex:00,00,10,00
"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\
00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\
32,00,5c,00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,34,\
00,00,00
@="Windows Installer Package"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\DefaultIcon]
@="C:\\WINDOWS\\System32\\msiexec.exe,0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell]
@="Open,Repair,Uninstall"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Open]
@="&Install"
"MUIVerb"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,\
6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,36,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Open\command]
@=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,\
73,00,69,00,65,00,78,00,65,00,63,00,2e,00,65,00,78,00,65,00,22,00,20,00,2f,\
00,69,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Repair]
@="Re&pair"
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,37,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Repair\command]
00,66,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Uninstall]
@="&Uninstall"
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,38,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Uninstall\command]
00,78,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
Good Luck and don't forget to leave a rating,
Thanks Mark
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
