Question about Brother DCP-330C All-In-One InkJet Printer
Why do I get Error message "no cartridge" message after installing new cartridge
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Help me please, i have new HP j3508, but when i install new cartridge into my HP 3508, the message on the screen says :"Cartridge Error" cartridge on right is not intended for this printer... help me
You need to remove the cartridges, see to it that the colored cartridge are olaced in its right location the same as with the black cartridge to avoid an error.
Jan 09, 2013 | Office Equipment & Supplies
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
New cartridge, says cartridge error
1. Try removing the cartridge and unplug units a/c power.
2. Find a damp cloth and wipe the output ports on the bottom on cartridge. .
3. With a Q-tip, go over the round copper pumps on the cartridge tray. ( Where the cartridge makes contacts. )
4. Close door and power up unit.
Unit will give you a error message cartridge not installed.
5. Install the new cartridge.
Close door and fallow any additional instructions given.
( A ) If this does not resolve your problem, re-install old cartridge and see if you get the same error message. If you do not, replace the new cartridge.
Hope this has resolved your problems.
Please rate your techs.
Oct 06, 2009 | HP Officejet J3680 Multifunction Printer...
Installed new black ink cartridge on Kodak ESP7. Cannot get rid of Error Message (saying need to install black cartridge!). Help!
Kodak had a batch of bad cartridges, I got 3 of them. All come from China. I used the online chat to describe the problem. They promised to send me new cartridges.
Jack
May 11, 2009 | Office Equipment & Supplies
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Cartridge Error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Installed new cartridges; keep getting error message
I'd say your using dodgy aftermarket or non HP cartridges, you could put your old ones in and see if message goes away, if having problem when using with Original HP cartridges post back and I'll did deeper for you.
I dont work for HP, I do know printers :-)
Dec 28, 2007 | HP Deskjet 5440 InkJet Photo Printer
Brother DCP-330C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
