Need unlock code so I can use any network it's a Nokia 6300 imei... 353508028289283 phone is locked to Vodafone Australia my email is [email protected] plz help
You can get an unlock code from your service provider or else try to buy an unlock code from any one of the online unlocking service provider like SuperUnlockCodes.com Here you can unlock your Vodafone network lock at low cost.
SOURCE: Unlocking codes for nokia 6300 from australia
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
SOURCE: Nokia 6300 Australia Vodafone requesting restriction code
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI:
353508029865248
Your unlock code is:
426850229882845
Manufacturer/Model:
Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY
UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only
using SIM cards from Vodafone Australia. In
case of difficulties, please refer to the FAQ listed below
1.
Take note of the unlocking code shown above
2.
Insert a Non-Vodafone Australia working
SIM card.
3.
Ensure the phone is charged and then switch the phone
on.
4.
Optional
Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5.
The phone will then display a message. The most common
is “Phone
Restricted”. Select
“undo” by pressing the middle
soft-key button. (Different message? See FAQ below)
6.
Carefully read step 6 before
attempting to enter the unlock code. This step has the potential to PERMANENTLY
BLOCK YOUR PHONE!
Enter into the phone #pw+ followed
by the 15-digit unlocking code then +1#
(Unlocking code is shown above). Do not
enter the 15-digit IMEI number by
mistake
To enter +
press the * (star) key two times
To enter p
press the * (star) key three times
To enter w
press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in
sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it
disappears? See the FAQ below)
7.
Then press “OK”
8.
The handset will display “Phone
restriction off”
unlocked after successful entry of the unlocking code. This will be confirmed if
you can make and receive calls with the Non-Vodafone Australia
SIM card. (You will need reception and phone
credit with the different network provider)
