How do I reset v-chip
SOURCE: mitsubishi HD 1080 series model ws-65807 no volume.
You need a remote. There are places that sell them, but you can usually get by with your cable box remote or some other modestly programmable remote. It would help if you had an owner's manual. You can probably find one on line. It is a bit of a dance to make the menus work correctly.
My set is gone, but you have fairly ordinary on-screen menus. One of them is for sound on or sound off to the internals. That so that there isn't the conflict between speakers from a receiver based audio setup. You should have external speaker outlets on the set itself. If you do, plut in a speaker you're not worried about. you should get sound out from there.or use an audio out connection to a receiver, etc.
SOURCE: Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
SOURCE: Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV
VChip Password
Bypass Mitsubishi HDTV
Front Panel Lock
SOURCE: can not turn off the vchip channel lock on hd 1080
hello try this
Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
