How do you replace the transfer belt on hewlett Packard CM1312nfi
SOURCE: We have four computers, 3 Macs and a PC networked
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
SOURCE: my HP Printer a CM1312nfi mfp printer is printing
if the printer has not been used for a while the other colours may have dried out..
try using cargtridge clean function on your printer to ensure all cartridge heads are clean.
I hope this was helpful.
