For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
5 02 Copy lamp lighting abnormalityH2 00 Thermistor open
H3 00 Heat roller high temperature detection
H4 00 Heat roller low temperature detection
L1 00 Scanner feed trouble
L3 00 Scanner return trouble
L4 01 Main motor lock detection
11 Shifter motor trouble
L6 10 Polygon motor lock detection
L8 01 No full wave signal
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication
Go To Below official Epson Printer Page For Your problem, Product Status Messages Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
hi Edgar Allan Pagayona, I read you comment. I have Epson sx425w. Facing the same error E-02. I tried to find it out the switch as you explain but didn't get the switch. Can you please tell me the exact location of the switch. Thank You. Looking forward for your reply. Regards, VIPUL
Sharp AR-450
H5
01
Papersensordefective in the fusing unit
02
Fusing unit temperature error
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
Image Processing Unit error
01
Memory back-up battery dead
02
Laser unit problem
03
HDD defective
10
black level calibration error
11
white level calibration error
13
CCD calibration error
90
F1
00
Lost communication with the Sorter
01
Sorter registration problem
02
Paper transport motor overloaded in sorter
04
Bin position error in sorter
05
06
Shift sort motor overloaded
08
Stapler position error
08
Stapler overloaded
11
Sorter problems
14
Second shift tray jammed
15
Sorter drive problems
50
Sorter not installed properly
80
No powerin sorter
F2
00
ID pattern reading error
02
Toner add mechanism malfunction
31
32
39
Drum thermistor error
F3
12
Paper does not lift in the tray
22
F9
00
Printer board problems
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
Overheated fusing unit
01
H4
00
The fusing unit doesn't heat up
01
H5
01
02
L1
00
Scanner position error
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
L8
01
Zero cross signal error
02
U2
00
EPROM error
11
EPROM error
U4
02
Duplex not working properly
03
Duplex problems
U5
00
Communication with the ADF is lost
01
Registration sensor problem in ADF
02
Exit sensor error in ADF
03
Timing sensor problems in ADF
11
Paper feed drive overloaded in ADF
U6
01
Paper lift problem in 1'st optional tray
02
Paper lift problem in 2'nd optional tray
08
Paper feed unit without power
10
PFU paper transport motor overloaded
22
50
Paper feed unit not installed properly
51
LCT not installed properly
U7
00
Main board malfunction
U9
00
Op panel problem
90
Op panel problem
EE
EU
Low toner density in the developer
EE
EL
High toner density in the developer
FA
01
PC
Key counter not installed
Sharp AR-122
Код ошибки
Подкод
Описание
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
01
02
Laser unit problem
03
HDD defective
10
11
13
90
F1
00
01
02
04
05
06
08
08
Stapler overloaded
11
Sorter problems
14
15
50
80
No powerin sorter
F2
00
02
31
32
39
F3
12
22
F9
00
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
01
H4
00
01
H5
01
02
L1
00
L3
00
L4
01
L6
10
L8
01
02
U2
00
EPROM error
11
EPROM error
U4
02
03
Duplex problems
U5
00
01
02
03
11
U6
01
02
08
10
22
50
51
U7
00
U9
00
Op panel problem
90
Op panel problem
EE
EU
EE
EL
FA
01
PC
Sharp AR-650
Код ошибки
Подкод
Описание
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
01
02
Laser unit problem
03
HDD defective
10
11
13
90
F1
00
01
02
04
05
06
08
08
Stapler overloaded
11
Sorter problems
14
15
50
80
No powerin sorter
F2
00
02
31
32
39
F3
12
22
F9
00
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
01
H4
00
01
H5
01
02
L1
00
L3
00
L4
01
L6
10
L8
01
02
U2
00
EPROM error
11
EPROM error
U4
02
03
Duplex problems
U5
00
01
02
03
11
U6
01
02
08
10
22
50
51
U7
00
U9
00
Op panel problem
90
Op panel problem
EE
EU
EE
EL
FA
01
PC
