Bosch AXT 2200 HP shredder motor turns the wrong way
I suspect this is a dud starter capacitor, meaning that the motor sets off in a random direction (whatever the direction switch setting). Can anyone confirm this is the cause of the fault?
Re: Bosch AXT 2200 HP shredder motor turns the wrong way
Try flipping the plug on the wall plug it in c which way the unplug rotate an plug it in again I no when working with. Motor proper polarity determined direction
Question edited for clarity.
Question moved from heating and cooling.
Absolutely the capacitor issue would make it run backwards. The purpose of the capacitor is to give the motor a high amperage jolt boost to get it turning in the right direction when you turn it on. It sounds like yours has a Start Capacitor and a Run Capacitor. Change them both. If one has failed, the other will soon follow.
hello for heavy machinery
u will find a lot of wiring diagrams and circuit diagrams and stuff like this at few sites I know
the girl in the chat box can help u instantly
Chances are there is a branch wedged in the blade assembly. Are you able to pull the starter cord? if not, you'll have to remove the housing that covers the blades and remove the blockage.
When you expose the blade use a bar to reverse the blade and release the tension, If it was blocked it should start up right away.
