I have a sussman series 500 steam iron and pressing table. The solenoid seem to be working, steam lines seem fine, but no steam comes out of iron. What could be the problem?
Take hose off from iron end,press iron button ,breifly! keep tight hold of hose [best to put towel around hose while holding]see if steam comes out.if not hose could be blocked, then take hose from solenoid end and press button .if no steam comes out the solenoid is either faulty or the valve hole inside is blocked,turn off power and take nut off top of solenoid ,check spring and plunger for condition.the small hole may be blocked in the solenoid housing,try a needle in the hole to clear any blockage.
