Will the TV control the Volume of red/white or optical audio output jacks? In other words are the fixed or variable outputs? The internal TV speakers will be set to off.
SOURCE: panasonic veira not working with the PS3 optical output
This sounds like a protocol compatiblity problem with the medias you are using. Check the set-up for the audio in all the devices connected to the TV set. Some of the older recordings and medias must have the sound set to simple stereo or mono. If there is no digital 5.1 data on the media source there is no way you are going to hear the sound if the equipment is set to that mode.
Jerry G.
SOURCE: Volume Problems: Panasonic TH-42PZ700U
please could you send me tips of what the problem of my plasma keeping stuck pixiel panorama LCD Tv model 42LC68T
SOURCE: I'm trying to use external
If I am not wrong this tv also has a stereo audio out . have you tried that? RCA audio outt with red and white ports?
SOURCE: I have connected my PC to Panasonic TH-L24C20D, I
If your computer has an HDMI output, the audio is already connected to the TV in digital format via its' HDMI input. However, if you are using the VGA from the computer, you will need a separate audio system to output the audio from your computer. The VGA is an analog video only. Your TV does not have an audio input so therefore you need a speaker system from the computer.
PS -- Yes I RTFM!
