A
Anonymous Posted on May 21, 2014
Repair kyocera fs-1028 mfp machine failure call service c7990
justin
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 58 Answers
  • Posted on Aug 04, 2014
justin
Contributor
Level 1:
New Friend:
Cheetah:
Answers
58
Questions
Helped
140001
Points
79
Developer unit fitted correctly or failure of developer unit .
1 Related Answer
Anonymous
  • Posted on Jan 21, 2012
SOURCE: Kyocera Mita Kyocera FS-1028 MFP Laser Print -
printer is working but scanner is not working
Hi, I have an error code C7990 on a Kyocera FS-1028 MFP. Can someone help me on translation and fix of this error?
empty drum unit its full of waste toner each side of drum unit has plastic covers that pop off empty out the unit thoroughly and vacuum inside
ERREUR MACHINE CODE C7990
Drum waste chamber needs emptying or drum unit replaced.
Kyocera fs-1028 mfp machine failure call service c7990
its a waste toner error put a new one in if the error persist check all the sensors you may also have to replace the drum
How to reset a process unit
Make sure that the front and top covers close smoothly and fully. If the blue toner release arm is not fully to the rear the top cover will barely close. To reset the process unit you should remove it and then re-install it making sure it makes a good 'click' when you insert it.
The waste toner container is located inside the drum unit.This code means the drum unit is full. To empty there are two caps that can be opened and the waste toner can be emptied. Usually the waste gets full when the unit is very close to be replaced. You may be able to get some more time if you empty it, but you will probably need to replace the unit soon.
Error occured call service person C7990
What to do if the current display is "Machine Failure Call Service C7990" but few days ago it displays "Toner Waste Box is Full".?
3helpful
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
