Genuine or Spurious Carbon Brushes for the motors used in Washing...
I located one web site which carries carbon brushes, however the company is located abroad. It would make the search easier if you the washer make and model.
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me from repairclinic.com. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
SOURCE: bosch washing machine
I just did this. Fitting the new brushes was fiddly but not impossible. Its easier if you remove the motor first as this makes access a lot easier.
SOURCE: remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
SOURCE: samsung washing machine carbon brushes (b1215j)
yes i have this carbon brush
how can i send u this carbon brushes .
where u live and from?
my e-mail address is
[email protected]
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
