Nokia N70 Cellular Phone Logo
m
magdalino rey Posted on May 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to activate pocket data for n70 - Nokia N70 Cellular Phone
IT Solution
Level 3:
  • Nokia Master 805 Answers
  • Posted on Jun 15, 2014
IT Solution
Nokia Master
Level 3:
Answers
805
Questions
Helped
156362
Points
2358
This is upon your mobile operator. You can contract with them. Thanks
1 Related Answer
rajat2392
rajat arora
  • 136 Answers
  • Posted on Mar 15, 2010
SOURCE: sir how cant i activate my pocket data for
in settings menu, goto configuration settings, and then to acess point
What to do if data network cannot be activated even if smartphone is internet and mms capable?
Try the configuration that's usually provided by your network provider.
Why i a\cant use the web browser in my nokia N70?
u may have not subscribed to packet data...your internet setting or configuration may not be available in your phone...or it might not be activated...ask for setting to your operator..they will send you in 1hr of request for free..after that you will be able to access internet..
Sir how cant i activate my pocket data for
5helpful
3answers
Nokia3110classic pocket data
you have to activate the gprs connection first and have to enable the settings for that.contact the network service provider
2answers
How to install themes
Here is your Pocket PC's default theme
wm6_default.jpg 1. Connect your Pocket PC to your Desktop using your cradle and Microsoft Active Sync, Once it is Connected double click on the green circle on your taskbar to open the Active Sync Window (If the Circle is grey, then it means that your Pocket PC is not properly connected).
2. Now you need to click on the explore Icon.
3. Here you can see the files and folders on your Pocket PC. Navigate to the “My Documents” folder. (This is where we suggest that you put your themes) . You can also use the“Windows” folder or Main directory of a storage card (not in a sub directory).
4.Now you need to drag the TSK theme files that you have chosen from your desktop computer to your pocket pc 5.Now you need to activate the theme file on your Pocket PC:
Tap Start, Settings, Today, Select your chosen theme, and tap OK.
Your new theme will now be activated.
You can download the themes from: http://www.htcfreeware.com/HTC/categories/HTC-Themes.aspx
2answers
How to open GPRS
I did not sovle it, it is the network that has the problem i presume.. i have another problem i download games for my n70 but i can't open it please help me. Thanks a lot,
6helpful
4answers
My n70's back camera is not working properly.it take several minutes to be activated.if it is activated.itis stopped with in one second.my bluetooth is not also working properly.plese help me?
Please check your back shutter it connected with a camera switch.
Remove the back of your phone & then set it again.
When you transfer data through Bluetooth, your phone should be directly in range of 10-15 metre
& your phone must be in "Shown to all" to work properly.
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
