I NEVER HAD A PASSWORD ON MY OLD LAPTOP,HAVE NOT USE IT IN A FEW YEARS,NOW TRYING TO START IT,ASKING FOR PASSWORD IN THE BLACK BACKGROUND WHEN I START IT
SOURCE: PASSWORD FOR BIOS OFR A SATELLITE A130/A135 SERIES
some set a password for you laptop.. you need to contact toshiba for this and prove ownership for the laptop.. or... you can try to open up your laptop and short the bios battery so it would reset..
SOURCE: Hi My Toshiba Satellite PRO L350 just went blank.
It should still be under warranty. Find the documets that came with it and contact Toshiba.
SOURCE: unlock bios Toshiba Satellite Pro A60FR !
This WEBSITE should help you out:
http://www.tech-faq.com/reset-bios-password.shtml
SOURCE: Suddenly my Toshiba Satellite A205 laptop died. No power.
First, check your power supply (the adapter). Is it putting out the required voltage to charge the battery?
If not, then you might have a dead battery and no way to charge it.
If the power supply is working and when you turn on the computer you get no lights, then you're probably looking at a new motherboard.
If you get startup lights and hear the fan, then it's getting power and you might have a video problem. But it sounds like, from what you wrote, there is no activity at all when you try to start it. That would be the power circuit on the motherboard, most likely.
SOURCE: hi i am an indian.sir
Hi.
If you dont remember the BIOS password, you may remove it by resetting the BIOS password.
Please follow the below steps to reset the BIOS password:
1) Please remove the bottom casing of the Notebook.
2) Once you have removed the below casing, you should be able to see a CMOS Battery.
3) The CMOS Battery will be of a size of a coin.
4) Once you have found the CMOS Battery, please remove and re-insert it again.
5) The CMOS Battery will have the information about the Computer Date, time, BIOS Password etc.,
6) Removing and re-inserting the CMOS Battery will reset these settings, which will also remove the BIOS password.
Please perform the above steps and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
