If I understand what you are needing to do is to Disable Print Job Notification in Event Viewer for Windows Vista Home Premium
When you are in the registry editor
and at
System Key: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers]
you should have seen and entry, right ?
name type Data
eventlog Reg_DWORD 0x00000000 (0)
To change the DATA value, double click on the NAME
Eventlog A small window will open that says
"edit DWORD value"Value Name: event log
leave this the same, it is not changeable
Value Data:
Change this data to 0
You can go back into the registry to confirm this value was changed, then turn off your computer and turn it back on again.
This should work for you.
