Canon Speedlite 580EX II TTL Flash Logo
A
Anonymous Posted on May 20, 2014
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week shots and then a couple of good shots and then again full power shot. I tested the same setting with other cameras and no problem there. Can be something wrong with my 5D Mark II?
Alex Wiilliam
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 18, 2022
Alex Wiilliam
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
656
Points
17
Doberman
Level 2:
An expert that gotĀ 10 achievements.
An expert whose answer gotĀ voted for 100 times.
  • Expert 261 Answers
  • Posted on Aug 17, 2014
Doberman
Expert
Level 2:
Answers
261
Questions
0
Helped
83963
Points
368
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
[email protected]
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Apr 29, 2007
SOURCE: Battery dies right away
You might want to try NON rechargeable batteries, particularly "digitally" rated alkalines. If this won't do it, I'd take it to get looked at.
Anonymous
  • Posted on Jun 02, 2009
SOURCE: Canon Speedlite 580 EX II
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
MIke
  • 685 Answers
  • Posted on Nov 04, 2009
SOURCE: Iam having a problem getting the two flash units
Make sure the slave is far enough in fornt of the master flash to see it. If the two flashes are next to each other then the slave is not seeing the master signals.
Doberman
  • 261 Answers
  • Posted on Jan 18, 2010
SOURCE: reverting to ttl - master flash not firing
Hi Kate,
What camera that you are having problem with those flashes?
Will switching the two have the same problems.
Make sure it is fully pushed forward into hotshoe & locked:-)
Try shooting second current, this will save you the repair costs.
Your exposure compensation was set to zero, but was your flash compensation set at zero?
[email protected]
Anonymous
  • 3006 Answers
  • Posted on May 24, 2010
SOURCE: I mounted the Canon 580EX II to my Canon 5D Mark
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
How do setup so I can fire only main 580 using 600ex-rt as master. the camera is 5D Mark lll. Also if want 2-1 ratio what camera and flash modes should I use. I don't understand the instructio
This video on youtube explains how to setup and use the 600 RT as a master. I do a lot of shooting with master slave, but my equipment is Nikon. Your gear is an excellent choice making it possible to shoot with remote flash. Canon 600ex rt Step by Step Setup Guide
tip
1080p MOV Conversion-Import/Edit Canon 5D Mark II MOV to FCP X with ProRes...
1080p MOV Converter-Transcode/Edit Canon EOS 5D Mark II 1080p MOV to ProRes 422 for FCP X <br /><br />Canon EOS 5D Mark II is one of the best DLSR made by Canon. It shoots full HD 1920x1080p videos in MOV format. However, with the high quality MOV videos, you may find that the log and transfer method on FCP X does not work for them .Therefore, In order to edit the videos of Canon EOS 5D Mark II, <b><a href="http://www.aunsoft.com/video-converter-mac/">1080p MOV Conversion for FCP X</a></b> is necessary. I googled and found Aunsoft Video Converter for Mac as the perfect. <br /><br />How to <b><a href="http://1080p-converter.com/2011/07/top-notch-mac-camcorder-conversion-tool-convert-canon-5d-mark-ii-mov-to-prores-for-fcp-x-editing/">Import and Edit Canon EOS 5D Mark II MOV to FCP X</a></b>? <br /><br />1. Transfer Canon EOS 5D Mark II MOV to Mac <br />Connect Canon EOS 5D Mark II DLSR to Mac with a USB cable. Copy the MOV files to hard drive on Mac or from outside. The MOV videos will be soon transferred to Mac computer. <br /><br />2. Load 5D Mark II videos to Aunsoft Video Converter for Mac <br />Run Aunsoft Video Converter for Mac as the <b><a href="http://www.aunsoft.com/video-converter-mac/">Top-notch Mac Camcorder conversion tool</a></b>. Click the "Add" button to load the MOV videos to the program. <br /><br />3. Choose output format and destination <br />Click the "format" option, and choose Final Cut Pro &gt; Apple ProRes 422(HQ) (*mov) as the output format. Click the "Browse" button to specify the output destination. <br /> <br />4. Convert 5D Mark II MOV videos to ProRes 422 for FCP X <br />After the output format and destination are set, click the convert button under the preview window, wait just a few minutes and the converted Video from <b><a href="http://www.aunsoft.com/video-converter-mac/">Canon EOS 5D Mark II MOV Videos to ProRes 422</a></b> will be ready for you to edit on FCP X. <br /><br /><b>Tips:</b> <br />Aunsoft Video Converter for Mac can also convert videos for other softwares like <b>iMovie, Adobe Premiere Pro, Final Cut Express (FCE)</b> and various media devices like <b>iPhone 4</b>, <b>iPad </b>and <b>Motorola XOOM</b>.
5d mark II working without memory card ,but with memory card no working, how to resolve this problem
I have seen this problem some times. Usually it comes from a fail at the CF PCB (compact flash printed circuit bard) and it is necessary to change the board. Sometimes the problem is the "bent pin syndrome" that frecuently occurs by using cheap Flash Cards.
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
[email protected]
1helpful
What are lenses that are compatible with the canon eos 5d mark ii
You can use Canon EF lenses. Be careful not to use EF-S lenses, as they cast a smaller image circle for cropped-sensor cameras, not big enough for full-frame cameras.There are other third-party manufacturers that make lenses with Canon EF mounts, such as Sigma and Tamron. Each manufacturer has their own designation for cropped-sensor lenses, so you'll have to check the specifications for each of them.
1helpful
I have a Canon battery grip for my Canon EOS 300D but have no manual to tell me how to use it as the camera is 2nd hand, can i get a manulal or download one from anywhere
I understand there isn't a manual, just a quick how-to guide. Here's some basic use info from a review
http://www.the-digital-picture.com/reviews/canon-bg-e6-battery-grip-review.aspx
The Canon BG-E6 Battery Grip is designed specifically for the Canon EOS 5D Mark II as shown above with a Canon EF 16-35mm f/2.8 L II USM Lens mounted. To get the Canon BG-E6 Battery Grip into the position shown, the LP-E6 Battery is removed from the 5D II and the battery door detaches. The BG-E6 slides up into the battery compartment and locks into place via the tripod socket screw seen on the BG-E6 just below the lens in the above image. The BG-E6 provides its own tripod adapter threads - this functionality is not lost.
The Canon BG-E6 Battery Grip holds two Canon LP-E6 Batteries that deliver double the number of shots or video time from the 5D II. Alternatively, use 6 AA batteries in the included Canon BGM-E6 Battery Magazine shown below.
2answers
Iam having a problem getting the two flash units to sink. I have set the parameters by the book for the master and the second the slave. They are both on the same channel. They are both on the ETTL mode....
I have a Canon Speedlite 580EX, the flash will not go off.
Perhaps the unit is set to master/slave mode. Look into that.
hint: Press and hold on the zoom button to get into the master/slave menu
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
