Canon PowerShot SX100 IS Digital Camera Logo
A
Anonymous Posted on May 19, 2014
Playback mode menu function
2helpful
Nikon coolpix s4 camera: want to download internal memory pics onto my camera card and need to find "copy" in playback menu but can't find playback menu. Can you help?
Press the Playback button (the right-pointing triangle, just to the right of the MENU button) to enter the Playback mode then press the MENU button to bring up the Playback menu. Copy is the seventh item on this menu.
1helpful
How to find playback menu
My hd 3 v5061u is on test mode how do i get it off
With your camcorder powered ON, and set to VCR / playback, there should show on the screen (viewer) something indicating "Menu" or a "FN" (Function) option. Select "Menu" (or Function icon to lead to the Menu). Check through the Menu options to find "Mode", and find the option for Normal Recording or playback, as opposed to "Test Mode", or "Demonstration Mode".
If this does not solve the problem, try this: Turn the camera OFF, remove camera battery, re-install battery, turn camera ON and see if that Re-set the camera. If not, it might be resolved by manually resetting the time and date. Then go to the Menu again to set Mode to normal recording or playback.
If those do not correct the problem, there is no shame in calling the camera company to speak with Tech-services. That's what they are there for.
1helpful
My vivtar 8025 camera locked my pictures so I can't delete the, how do I unprotect them
1. Press the Home button.
2. Enter Playback mode by touching the Playback (right-facing triangle) function area.
3. Press the Menu/OK button.
4. Touch the downward arrow function area until the Protect option comes up.
5. Touch the key icon function area to enter the Protect menu.
6. Touch the left arrow function area to select Lock or Unlock.
7. Press the Menu/OK button to confirm.
This should be on pages 29-30 of your manual.
Internal memory full - how do I find it? Ann
If you do not have a memory card inserted, the camera defaults to the internal memory, both in shooting and playback modes. You can transfer from internal to a card using the "copy" function from the playback menu. The internal memory can be erased from the playback menu using the format function in the "setup" menu. Don't erase (format) until you are sure the images are stored safely elsewhere.
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
2answers
No Sound
The camcorder may be in what may be called "narration mode." This function mutes the playback audio so you can narrate with you own voice when playing tapes back. Check for a function like this in the playback sound menu.
Menu display help..
change the rbg. push that button once and it will take you so that you will be able to view everything. it is probably in dvd mode.
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
