Over time it will attack the motor, yes. There are pumps especially designed for salt water pools, with 316 stainless steel parts, and an open section in the casing between impeller housing and motor casing, and seals on either side with a flinger on the shaft. Eventually though the salt will get to the motor somehow. Mind you we are talking years. On my salt water pool, now 23 yrs old, it is on its 3rd motor, which is about 5 yrs old.
SOURCE: wiring two 240 v loads to a switch
threw a intermatic t104 timer, hook the salt gen. to the same side as the motor .. you should have a timer already on the house for the pol pump ? use it the same way .. Jay the pool pump motor repair guy longwood Fl
