Able to take pic for other sites with permission but can't take and dwn. load to files
If you are using a recent Windows operating system, right click on the Start Button/Icon on the lower left of your screen at the end of your tool bar then click Properties. You will have a window pop up that should have three tabs. The left most tab (top of the window) says taskbar. Select that. Once that is open, click "Customize" (it won't have parentheses) which will give you a window with options of what icons should appear and when. Just find your camera and select when you want the icon to be visible and click Apply (or OK, depending on your OS) and you should be all set.
You can also make sure that the device is powered on, when you connect it and if there is an installation disk that came with the device, be sure to use that. Always start installing a new device WITHOUT the device connected and follow directions until it tells you when to attach it.
GOOD LUCK!
