How do i get it to boot up or start it won`t do anything.i get a black screen.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
SOURCE: my dell dimension 2400 beeps morse code like and won't load
you have to follow the beeps very well to understand wat is the problem, each type of beep gives you sign for problem. so check if its one beep, two, or three, short or long, this makes very easy to you to define the problem.
Try to take out that parallel port if your pc works fine, this means this connector was not compitable to your board.
Best regards
Iām happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: my dell dimension 2400 will not boot up. It goes
This can usually be solved by resetting the CMOS.
Unplug the power from the back of the tower. Open the side of your case and locate the round battery near the lower-right side of the main board. Pop the battery out. Just below it you should see 2 little gold colored pins sticking up. Right around it it should say 'Clear CMOS' in very fine print. Take a small screwdriver and hold it to the two pins so they are shorted or touching each other through the screwdriver for a few seconds. Place the battery back in the machine and see if this works.
SOURCE: I am unable to get into the Safe Mode on my Dell
You have noticed what is written, not always what happens.
If you are able too run, through setup, click on help &support.
Search box, type in Safe Mode. Follow instructions.
F8 is the key, when starting up keep clicking the key as the poota wakes up, it should give you a choice menu for you access up/down with arrow keys?
