Konica Minolta Konica Kit For Bizhub Press C7000 350k And C6000 300k Dadupm3500 Logo
A
Anonymous Posted on May 18, 2014
How to fix 2231 error code? - Konica Minolta Konica Kit For Bizhub Press C7000 350k And C6000 300k Dadupm3500
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 10, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910204
Points
11959
Could be one of these, start first with the Y drum
Anything else get a tech out power supplies and printer control boards are serious money$$$$$$$$$$$$$$$
• Printer control board
(PRCB)
• Drum motor /Y (M14)
• Encoder sensor /Y1
(PS81), /Y2 (PS82)
• DC power supply /2
(DCPS2)
• Drum Unit /Y
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
How do i reset the error code c2231 in konica minolta press c8000
C-2231 is the M-13 Filter Cleaning Motor, best have a tech come out because motor is deep inside machine. Power on off is reset. worse case is Printer control board $$$$$$$$$$$$$$$$$$$$$$$
I have bellsouth two way radios, model number 2231. One of them says busy all the time so it prevents us from being able to talk both ways. Anyone know how to fix that or have a manual for them?
Decrease the sensitivity of your Radio by increasing the value of squlech level and check your bussy signal. Also change the place and see your bussy signal goes off or not. If not then send it to my workshop or your nearest service center.
Code p 2231
Auto Zone, as well as any mechanic or dealer service dept. would have the key to any vehicle codes.
Dbx 2231 not working
Probably needs a transormer, I have replaced enough of them..
Coleman hand rocker pump 2231 - seal is gone. Is there a way to repair? Are these still available?
For others, not the OP from ten years ago:
Search Amazon "JR Products 97025 Chrome Manual Water Faucet" and this might be the same mechanism and parts as your Coleman 2231 pump. I went to my local shop in Calgary (starts with an H and ends with obo's, fixya considers that word to be profanity so I can't use the name H*bo's) and they had them there for $39. I swapped the plunger, cork and cylinder from the new one into my Coleman 2231 and will keep the bits from the new one for possibly the other parts in it.
Ac adapter 0957-2231
Are you looking for an Ac adapter for your computer?
Then it is this one from HP:
http://www.amazon.com/HP-0957-2231-AC-Power-Adapter/dp/B000X4421Q
1helpful
What is the manu code number for this unit
hi! i have here a couple of codes here for your toshiba, just try them,1154, 2093, 3099, 1158, 2094, 3098, 1338, 2094, 3149,1116, 2054, 1293, 2210, 1294, 2210, 1345, 2231, hope this helps!!!! goodluck!!!
LOOKING FOR HANDS FREE HEADSETS FOR BELL SOUTH MODEL #2231
Which model exactly is this...2231 or 2280wp?
A 2280wp is already voice activated. DO NOT push the PTT button, turn on the radio & talk.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
