Computers & Internet Logo
k
krishankant Posted on May 19, 2014
Programme crashes arrow does not functions
The programme suddenly crashes picture stands still but sound remain functioning .arrow does not functions it does not works t
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
1helpful
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
My camera keeps saying the card is full when its brand new
You just need to format the memory card. And make sure that you are in memory card option for the picture storage when you take pictures.
Formatting the memory card This function will format the memory card and will erase all files in memory including files that have been protected. Note: Once formatted all the images stored in the memory will be erased. This process is irreversible. Please download all images to the PC before formatting the card. 1. Touch the icon (arrow down) function area until you see the “Format” option.
2.Touch the icon (memory card drawing/picture) function area to enter the Format menu.
3.Touch the icon (arrow left) function area to select OK/Cancel.
4.Press the Menu/OK button to confirm.
5.A Format message will appear on the LCD.
FORMAT?
YES NO
6.Touch the icon (arrow right) or (Arrow left) function area to select Yes or No.
How do I reset the Cyber Home 300 to defaults?
Check your owners manual. find the function by using the on screen menu, turn this on by pressing the menu button This function is usually in the setting functions and is usually found by using the up and down arrows to find the settings function and then using the right arrow to enter the function. After entering the function you should find the factory reset function among the listed settings.use the up and down arrows to find this setting and place the cursor on it and press enter and it should reset all the functions to the factory settings for you. Hope this helps you with your problem.
Plz i wanna help,my computer toshiba satellite m35x-s149 does't have sound,plz send me the programme for download.thanks
We need to know what is happening when you try to play a sound.
Do you hear anything?
This is a laptop and you can turn the sound on and off by using your keyboard--pressing the function key at the bottom left of your keyboard and then pressing the sound volume key which is one of the function keys at the top of the keyboard (the ones with the little speaker pictures on them).
Your Toshiba may also have a volume control on the side of the machine.
You must also check the control panel (the icon that says sounds and audio devices). Does it show a sound device when you click on it? Check to see if the "mute" box is checked. If so, uncheck it.
When you click on the Sounds tab, can you see Windows events at the bottom of the screen with little speakers beside them? If so, can you click on one of the events and then click on the right arrow just to the right of the sound events? Is the arrow dark or light when you click on the sound event? If it's dark, you should hear the sound. If it's light, you need to go to Toshiba's website and download the correct sound drivers for your computer.
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 • Dishwashers
System seems to have crashed
there is no way you can restore them consider the pictures lost you will have to delete them in order that your set wil function properly.
Grand Canyon Tech
Grand Canyon Tech
