SOURCE: where can i get the right driver for my Kodak Easyshare M340?
You can get the drivers here.
http://www.kodak.com/global/en/service/downloads/dln_ekn036196.jhtml?pq-path=14649
Good luck and please rate
SOURCE: I've got a Kodak m340 it turns on but turns back
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: i have a black kodak easyshare m340 and whenever i
Make sure your batteries are charged up, or new ones are installed. This is a very common problem.
SOURCE: Kodak EasyShare M340 Digital Camera
Maybe, the batteries need to be changed to new ones.
Try to use Li ion batteries as recommended by Kodak.
SOURCE: I CAN NOT FIND THE DRIVERS FOR MY KODAK EASYSHARE.
Hi,kindly get it downloaded here :
www.kodak.com/global/en/.../dcs1394InstallReadme.shtml
www.nodevice.com/driver/.../Kodak/Digital_Cameras.html
Regards,Jaya GTG
