The manual is at http://www.gigabyte.com/products/product-page.aspx?pid=2331#manual
The choice is among twenty languages.
SOURCE: warranty
contact Gigabyte at www.gigabyte.com and ask them directly. As they do not post it in specifications.
Thanks,
Lee
SOURCE: Gigabyte GA-945GM-S2
Hi FRND,
check this link for the drivers which you want....
http://asia.giga-byte.com/FileList/Driver/motherboard_driver_lan_realtek_8111.exe
Enjoy...
Regds,
DRSS...
SOURCE: My PC have no external AGP card. The motherboard
it can only be done in the bios settings.
but you cannot get 128 mb. normally the onboard sharing will be set a max to only 8,or 16 or 32. maximum. only reputed graphic card company like nVidia or ATI radeon will give the adjustment of sharing memory of onboard vga to that level.
this can also be done only in the bios settings only.
normally under the display tab. or advanced tab in the bios settings.
SOURCE: i have a motherboard gigabyte 945 gcmx-s2 but
You can find all drivers from this motherboard here: http://www.centraldriver.net/driver.php?codigo=1746
SOURCE: Problem for Gigabyte 945GZM-S2 Motherboard
HI,
There is only one memory stick that that board will support that is a 2gb chip. You can reveiw all the tested memory HERE, to see what will work prior to buying.
Good Luck,
Mark
