Do you have a downloadable manual for a Dictaphone 3740 voice processor
SOURCE: "No Cassette"
There is a small switch mounted ion the tape deck. You may be able to take it apart and slightly bend the switch upwards so the switch will be activated.
SOURCE: lost manual for dictaphone 2750
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
SOURCE: 20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
SOURCE: Where to get earphones for Dictaphone Model 2470
Hello go to www.tvps.com then go to headsets cassette they are alot of different styles for Dictaphone 2 prongs Headsets I attach some links
http://www.tvps.com/Products/Dictaphone-304712-Wishbone-Style-2-Prong-Transcription-Headset---New__DI-304712.aspx
http://www.tvps.com/Products/ECS-AL-60DP-Aluminum-Stetho-Style-Headset---New__VE-AL-60-DP.aspx
http://www.tvps.com/Products/Dictaphone-0HST002-Deluxe-Headset---Pre-Owned__DI-P-0HST002.aspx
SOURCE: I have a Dictaphone Desktop Voice Processor Model
It's possible the play capstan belt is broken - or the main capstan motor is stalled.
