Question about A.O. Smith SQ1102 Pool Pump Motor
Where can i find a swithch for hayward super pump part number 627953
My pool motor tripped my breaker. When I reset the breaker and it tripped again sparks came out of the motor. Can someone tell me what the problem is more likely to be? I don't know the make of the motor...
The title description is a Hayward Super II 1.5 HP but the part number you gave is for a StaRite MaxiGlas pump. Either way the motor needs to be replaced.
The best way to find out what you need is to look at the part number on your impeller. With that information whoever you buy the motor from will be able to get you the correct pump and seals..
Oct 30, 2013 | Hayward SP3015EEAZ Super II Pump 15Horse...
Where can I get a new start cap for a 1 hp Hayward super pump
Find out your model number on your pump by checking the hayward site, for the super pump the parts manual is http://www.hayward-pool.com/pdf/Parts%20Diagrams/Super-Pump.pdf
Once you figure out the part number for your super pump you can call a local pool and spa shop and they will order it, you can google the part number, buy it off amazon (personal choice), or call hayward at (908) 355-7995 (U.S.) to buy a replacement
Oct 05, 2013 | Hayward Pool & Spa
What's the capacitors MFD-rate on a Hayward super pump?
this depend on the pump horse power look at the cup is should have this numbers on it
Oct 04, 2013 | Hayward 1HP Super Pump II Inground Pool...
Pool pump sp2607x10 hayward capacitor????
They can vary from year to year.
There is a model number and a code number on the motors label.
Jul 21, 2012 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL : C48L2N134B1 1 1/2 HP 115/230 VOLTS IT IS BROKEN AND I WANT TO KNOW WHAT MODEL I SHOULD BE BUYING TO REPLACE IT WITH. THE MODEL NUMBERS ARE DIFFERENT...
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Thanks for your interest in FixYa.com
Aug 11, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward super pump 1.5hp motor seized due to water damage. can it be repaired?
no...write down all the numbers on the ID plateand go get a new one...the numbers will make sure you get the exact motor you need...electric motors are general, based on the numbers...
Apr 10, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Hayward 1hp super pump stops working
Your motor has a thermal protection switch in it the reacts to an overheating condition. Once the motor cools enough it will turn back on. You may be able to have the motor rebuilt for about half the cost of new if it is not damaged to severely. Take it to a local electric motor repair shop for service. If it is damaged beyond repair, you can shop around for a new one. If you would like a quote, contact us at www.arrowpools.net with your pump model number and we can quote it.
Jul 12, 2009 | Hayward Pool Products HAYWARD 1 HP 2 SPEED...
A.O. Smith SQ1102 Pool Pump Motor Logo
Top A.O. Smith Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
