A
Anonymous Posted on May 16, 2014
What is the dell 5650 pinout of d connector? - Dell A425 Computer Speakers
5 Related Answers
Donald B Stoll
  • 597 Answers
  • Posted on Jun 01, 2009
SOURCE: Need pinout for front pannel connector J60H1
Go to www.intel.com and search for the E210882 number. It is an intel motherboard.
Donald B Stoll
  • 597 Answers
The E210882 number is a certification mark for some Intel motherboards. But that is not the number of the board. Try to find a number that begins with and "E" or a "D" then three numbers and then 3 or 4 more letters and numbers combined.
Anonymous
  • 17 Answers
  • Posted on Feb 17, 2010
SOURCE: Control panel connector pinout for Dell Dimension 1100
Well the official Dell manual can be found on their website here. I don't know if this helps or not, but I hope it does! :)
James Miller
  • 2226 Answers
  • Posted on Mar 24, 2010
SOURCE: need dell gx280 tower CPU fan pinout (5-pin connector)
dell has web download manual jim
johnwmaustin
John Austin
  • 222 Answers
  • Posted on Sep 20, 2012
SOURCE: what is the dell optiplex 320 front panel connector pinout configuration?
Try http://support.dell.com/support/edocs/systems/op320/multlang/QRG/EN/JK5231A01.pdf
or http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=OptiPlex+320&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=tab
Dell MMS 5650 Home Theater Speaker System 5.1 100W. I have to make a input connector for MMS 5650. Where does each pin go please?
Question edited for a lot more clarity.
Probably easier to buy a new refurbished one for $45 and copy it. There is no Service Manual for it, just the Owner Manual.
https://www.google.com/search?q=Dell+mms+5650+input+pinout
Dell MMS 5650 Home Theater Speaker System 5.1 100W ...
DBCS Computer https://www.dbcscomputer.ca > ... > 5.1 Speakers
MMS 5650 Home Theater Speaker System. Type, 5.1. Total Power, 100W. Frequency Response, 40Hz - 20KHz. Headphone Jack, 3x 3.5mm. Volume Control, Yes. Power Type ...
$45.00 · ‎In stock
Manual
https://www.google.com/search?q=Dell+mms+5650+service+manual
1helpful
2answers
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
http://pinouts.ru/Video/VGA15_pinout.shtml
1helpful
My Dell 5650 Woofer isn't working.
Please download the manual for Dell 5650 and check the placemat details if anything is missing.
http://support.dell.com/support/edocs/acc/p62507/
And update me if that helped.
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
