SOURCE: putting music on the lg prada
you need to plug the usb you had with the mobile where you insert the charger with pc and transfer data or music from pc to the mobile.
try to plug the wire usb first . on your pc it will open a page written as removable disk .
the open your music documents make copy the one you want and on removable disk make paste you can work with this
SOURCE: LG PRADA / KE850
So there is no way to fix the phone if there is problem(ex. not working screen)?
SOURCE: Lg Prada KE850 will not turn on, just has the white prada logo
**** les gard jais mon lg ke850 qui salume par momen
SOURCE: CHANGING HOUSING FOR LG PRADA KE850
Hi Purnimakant,
It's very easy to do and I have done it myself.
If you check out:
http://www.formymobile.co.uk/Dismantle/ke850disassembly.htm
There are step by step pictures there.
You can find a new case on eBay. I changed from black to silver :)
Hope this helps.
SOURCE: need puk code for locked LG KE850prada phone
If you need the PUK ( Personal Unblocking Key ) for your phone, you will have to contact your mobile phone service provider.
PUK code is related to the SIM card you are using. So, kindly call the Customer support of your mobile service provider and they will provide you with the PUK code.
Also, entering a wrong PUK code ten times in a row disables the SIM card permanently. So, please be careful while entering the PUK code.
Hope this solves your problem. Thanks for using FixYa.
