My tablet that I purchased four months ago is now giving me heck. All I can do is turn it on and it just freeze on a dark screen with the word Android glistening in silver. Please help me reboot my Zeepad 7.0 . Thanks
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
There should be a tiny hole on the side of the tablet to reset your tablet, you will need a toothpic or paperclip to insert into the hole. If this does not work try removing the SD card on the back & reinsert it. If all else fails take it back to where you bought it & ask for help!! Hope this was helpful.
Try flashing your zeepad. Find instructions here:
http://www.zeepad.net/Zeepad%20flashing%20instruction.pdf http://www.zeepad.net/Zeepad%20flashing%20instruction.pdf
visit www.zeepad.net
find software needed for flashing @ www.zeepad.net
This is now a dead link, reaches a 404 error page in Chinese.
Buy a mobile broadband dongle. You will then have the advantage of 3G internet access. These dongles are readily available in mobile phone shops.
SOURCE: My Zeepad 7.1 Android screen is cracked how do i fix it.
mi tablet se me descontrola la pantalla
SOURCE: my zeepad 7.o android will not pass the first screen showing zeepad alone.
Am having problem to open up my tablet, when i powered it the icons don't show up for me to unlock it.but it shows the wifi signal and the screen picture i put on.
SOURCE: How do I transfer my contacts from my android phone to my android zeepad 7?
You can transfer them by the following ways:
1.google account, if you have a google account, you can sync your contacts from the phone, the sign in the accoutn in zeepad, the syns again.
2.backup as a vcf files in SD card, you can make a backup to the phone sd card as a vcf files(you can set in contact app), then copy the vcf files to the zeepad,finally you can lead it in .
3.3rd-party android assistant, most of assistant can make a backup for the android contacts,or lead them out as a files, so you can try to use it.
SOURCE: how can i unlock my zeepad 7.0 tablet
how can i unlock the screen. i charged the Bat for six hours and held down the power button but the screen shows locked
