How do I get to the recovery partion or system restore without the disc
Dear Lizanne,
To get to the recovery partition on your Compaq Armada M700, turn on the notebook and press F11 repeatedly until "Windows is loading files..." displays on the screen. Then, follow the on-screen instructions.
If your notebook originally came with Windows XP or an earlier version of Windows, try pressing F10 to enter recovery instead of F11.
Hope you may find these instructions useful!
Best regards,
Miguel L. Martins
SOURCE: Compaq Armada M700 Shut Off During Windows XP Pro boot
It's usually caused by the Voltage-Regulator sub-board that is faulty M700/M300 - same problem. If the VR sub-board is replaced and problem still exists, mobo is faulty.
SOURCE: Compaq Armada M700 - failure to boot from CD
Hello Blessie,
This is Romeet,i shall try and help you with this problem. Before formatting for a new installation of w2k, did you delete your partitions and create a new partition or did you just overwrite the old installation partition?Besides i hope you did a backup of your data before any of above processes in the event you might need it later on? Please let me know about the partitioning and i shall try and help further accordingly as most likely it looks like a Disk Partitioning Misconfiguration / Problem
Regds
Romeet
SOURCE: installing wifi in Compaq Armada m700??
yes,
aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series
it's alot better
SOURCE: 101-I/O ROM error and 162-system option not set
sound slike theres a fault with a cd dvd drive or that it's disconnected, possibly the driver is corrupt
SOURCE: Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
