Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
What is the meaning of 5a error code on carrier window AC..?
2 Suggested Answers
6ya staff
SOURCE:
Keith Farley
  • 10 Answers
SOURCE: What does fr mean for
freon
Posted on Aug 16, 2010
What is the meaning of FR? Coz my carrier aircon w/ remote appear n LCD FR
All the Error Codes are here, but that doesn't appear to be a normal error code. Look in the manual. You can Google it 'make model manual'.
Carrier Split Air Conditioner AC Error Codes Troubleshooting
Apr 07, 2018 | Carrier Heating & Cooling
Carrier Ductable 11 Tr ac error code L2 Mean
voltage check 3 amp fuse possible bad motor
Jul 25, 2017 | Carrier Heating & Cooling
I have a window carrier ac 1.5 ton. display show 5A what is this
Its not 5A but SA means energy saver mode.use remote to change to cool mode without energy saver.
Sep 09, 2016 | Carrier Heating & Cooling
I have a carrier window ac error coad 5a flashing for some time ac not on
Its probably not 5A but SA. And SA means sleep auto it activates on pressing the energy saving button on remote. Its not an error but a feature.
Apr 01, 2016 | Carrier Heating & Cooling
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
What does the code E1 mean on Carrier Model # 38KCL112313GP?
thermostat no recognizing ac unit turn off and reboot thermostat
Aug 05, 2014 | Carrier Heating & Cooling
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
657 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
