I put a pair of shoe in the dryer and they did dry but after it stopped I no counger could run start they dryer. The front control panel still lights up and you can adjust the settings but it will not turn on. Any suggestions?
It sounds like the problem may be with the door lock. Having shoes bouncing around in the dryer they are bound to hit the door over and over possible causing damage to the lock. Try pushing on the door and holding it shut while you turn on the unit and see if it works.
SOURCE: Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
SOURCE: samsung front load dryer had a burning smell-it
ck recalls on this issue.
there may be one.
under warranty??
do not buy samsung they are notorious for having problems.
sounds like the heating element and relay may have went out.
however if it does not start up at all it could be the motor itself.
SOURCE: Whirpool GGw9250Pw3 no power on Control Panel Inside light works
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
SOURCE: dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
