Is the powerboard bad, does the firmware need an update? Any suggestions? I've been looking around a and a lot of people say that similar issues are due to power issues, either a board fry or something that can be fixed with a firmware update. I'm not a Toshiba TV guy though and don't know!
SOURCE: Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
SOURCE: Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
SOURCE: Toshiba 47HL167's screen has gone Completely Black
I don't know if you guys are still looking for an answer but turn the TV on where you can here that something is actually playing on the TV then grab a flashlight and turn all the lights off. Get real close to the screen and shine the flashlight on the screen. Can you see something on the screen? If you can then there is a very good chance that one of the inverter boards are out. This could be the slave or the master. For the 47" I actually have the same issue and have ordered the master inverter board. For the 42" I have both the master and the slave board and they are both working. So for the person that has that issue on the 42" TV if you want a board for your TV email me at [email protected]. For the one with the 47" flip a coin and order an inverter board for it either master or slave and try it. To determine which inverter board it is you would have to take the DC voltage across the start and then the end to see if you are getting any power. I hope this helps. By the way inverter boards usually run between 60-120 dollars each and the slave board on both these TV's are easy to install. The master is a little harder due to the power button board is in front of it and has to be removed first. Let me know if this helped.
SOURCE: Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
SOURCE: Toshiba Regza 47HL167's screen has gone completely black
Reset the TV. There instructions in the manual on how to reset.
