These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
Electro help
If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in '
I am having the same problem i have no picture or sound but the standby is on have u had any suggestions
When turning on the television, the standby/timer light blinks red, and the screen stays black. Anyone know how to fix this problem? I've already tried resetting the TV using the reset button and unplugging it completely. No luck so far.
