Insignia LCDTV26 26 in. Television Logo
A
Anonymous Posted on May 15, 2014
Where can I get the screws to put tv back on tv stand
2 Related Answers
Steven
  • 15 Answers
  • Posted on Sep 06, 2008
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Anonymous
  • Posted on Jun 19, 2009
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
How do I remove the stand to put my LT19C300 Samsung on the wall
Look for holes in the back of the TV just above the stand. There are screws in those holes that hold the stand on. Shine a light in one to see what kind of fastener it uses. Some are phillips head screws, some use hex head screws. Locate the tool necessary to remove the screws and take all of them out. Have someone help you hold the stand while you lift the TV off the stand.
5helpful
2answers
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
3answers
Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Putting the tv stand back on the tv
these are removal instructions should be helpful though
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
5helpful
2answers
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
2answers
Tv stand screws
3answers
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
