Does it crunch? If you lift the clutch and then press it down whilst trying to get it into reverse as this lets the cogs move allowing you to slip the drive into the gears this may allow you to get it into reverse. So here's the steps:
1 start the the engine
2 drive the car for about 10 kms
3 try and get the vehicle into reverse
4 lift the clutch whilst holding the stick in the gate ( you should feel the cogs turning and shaking the stick)
5 then push the clutch down again
6 if it still won't go repeat step 4/5
if it still won't work then try and get it into reverse whilst stationary and then start the engine it will jolt but can free up the gears!
hope this helps :)
SOURCE: i changed transmision fluid of toyota sienna 1998
Changing the fluid will never harm your trans unless you do not fill it back up.
Reverse is all hydrolic. There is no electrical that could cause it. If you have park and forward, you don't have a lincage problem.
As much as I feel for you, (I satarted rebuilding transmissions in the 80's) you will have to get it rebuilt.
Sorry
SOURCE: i can't find knock sensor location bunk 2 toyota sienna 2001
It's under the intake manifold...oh joy
Testimonial: "you are a nice guy. i'm so gratefull you have this in the networth. thanks."
SOURCE: 2001 toyota sienna power mirror/ clock not working...
There is an interior fuse panel located on the left side of the steering column, behind the "change compartment". You just pull it out and you will see a fuse diagram on the back. The fuse you want to replace is the fuse for the cigarette lighter, it is a 15 amp fuse and is located on the bottom right.
As far as I can tell, the owner manual makes no mention of this interior fuse panel and furthermore the actual fuse for the cigarrette lighter doesn't mention that it is connected to the clock and the power mirror.
SOURCE: My 2002 Toyota Sienna stalls when I put the car in
My 2002 Sienna just started doing this exact same thing. Curious if you ever found out what was causing this to happen?
SOURCE: I changed the battery in
Press station 1 and 6 and turn the ignition key to on position but donot start the vehicle, you will see the unlock code flashing, note the number that is your radio code, read your vehicle manual and insert code to unlock.
