Machine stopped and beeped and indicated EEE. The program can no longer be reset even if I unplug the machine. There is no pad keys control functionning. Is there a reset button/pin or kill switch for the program ? ...your system is in dire need of repair !!! I have been asking and following instructions for 1/2 hour without getting thru this S**T.
SOURCE: F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F0
Clock pushbutton is stuck in a depressed position
Check clock buttons
F1
Element relay circuit failure
Control board may be bad
F2
Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Call for service
F3
Short Circuit in the oven temperature sensor
Check oven temperature sensor for continuity, if no resistance (zero ohms), replace
F4
F6
Failure in the EEPROM check comparison (only time of day and timer will operate)
Call for service, electronic clock control is usually the cause of the problem
F7
Failure of the self- clean automatic door latch system
Check door latch and switch(es)
F8
Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode
Check door lock motor and door latch
SOURCE: Roland Spd-s pads not working
Check for a cracked PCB internally from the two defective pads, or if the wires have detached from the trigger. You may not need parts, but if you do, it really depends on how helpful the Roland distributor in your area is as to whether you will have any luck getting them, or you may have to go trough a local authorized repair shop.
Good luck.
SOURCE: Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I changed the batteries but beeping continues even after code
I have the same problem. Any one know a solution?
SOURCE: how do I start the
Use and Care Book for the Black& Decker All-In-One Horizontal Deluxe Automatic Breadmaker is here:
http://useandcaremanuals.com/pdf/B2300UC.pdf
It sounds like a programming error. Be sure you all following the setting and programming instructions completely and that the breadpan is propely seated in the unit.
