My Hp deskjet 1050 print and scan, I had changed the settings to print just in black. Now I want it to revert back to printing to color, but I have forgotten the settings, please can some one help me to go to settings and do the needful, as per factory settings. Thanks
Read more: http://www.ehow.com/how_6809266_hard-reset-hp-laserjet-1320n.html#ixzz31kIyBHut
I refill ink of hp deskjet 1050, but is not pprinting wee.. what should i do?
SOURCE: HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white
while the copier side is automatically detecting that your original is
in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
SOURCE: HP OfficeJet 5610 All In One alignment cartridges and no printing
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab101
SOURCE: HP Deskjet 5550 will not print black&white after cartridge change
Here is a link to a page that explains how to clean the cartridges:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=bpa00226
SOURCE: We want to default the printer to just print black
select your printer in printers and faxes. right click, select properties. select printing preferences. select grey scale under the color tab. click ok, ok. it will now always print in black and white unless you change it back the way the previous post suggests. that will be only temporary.
