Question about MSI K9N6SGM-V Motherboard
I assembled my PC but not the order of cable Power, Reset, letf, I say as pudes are located, plis
  • MSI Master
  • 5,660 Answers
The connectors you are referring to, are the Front Panel connectors. The wires come from the Front Panel, where your Power On button is.
The pins on the motherboard are called Headers.
Your Power On switch, (It's behind that button), the Reset switch, Harddrive Activity Lamp, (Light), and so on, connect to the Front Panel headers on the motherboard.
That explained, let's continue;
This is in reference to the MSI K9N6SGM-V motherboard. If this is not the model of your MSI motherboard, come back with an additional comment, and state the Model Number.
The link below is to MSI Support, and the download page for the ->motherboard manual. It is a Zip file. I'll explain how to open that file.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=1086
(Copy and paste the above link into your address bar, then press the Enter key)
Under the Download heading on the right, click on -> M7309v1.1.zip
(It's in Blue)
On the next page I recommend clicking on -> U.S, in the blue button.
A small window will pop-up. Left-click on the small empty circle to the right of -> Save.
Now, if you do not have your downloads set to go to your My Documents folder, (Start>My Documents), this will go to your desktop screen.
Minimize all windows that are open, to see your desktop screen.
On your desktop screen you will see a new yellow folder, with ->M7309v1.1.zip, underneath it.
Double-click on it. In the next window go up to the top left, and click on -> Extract all files. In the next window click on ->Next, then click on Next again.
(Same thing if it's in your My Documents folder)
Now click on-> Finish. You will now see a PDF file with -> 7309v.1.1(G52-73091X2).pdf
Double-click on that file name.
You will now be looking at the Motherboard Manual, for your MSI motherboard.
Page 7 shows your Front Panel headers. There are two of them. JFP1, and JFP2. (Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is on the bottom right. There are 5 rows of 2 pins each. The pins go down in a column. There is NO pin on the top Left of the column.
JLPC1 is a header to the immediate Left of JFP1. (It has 7 rows of 2 pins, but 1 pin is missing 3 over from the right side, and on top) Disregard the JLPC1 header. The JFP2 header is to the Left of the JLPC1 header.
It has 5 rows of 2 pins, with NO pin in the bottom right corner.
At the very bottom of Page 13 it shows you where your Front Panel connectors go.
(When I refer to the page numbers, look at the very top of the PDF file in the Square box. The Square box is to the right of the Blue Down Arrow.
I am not referring to the page number on the page itself)
Use the Additional Comments if you have further questions about this.
Posted on Aug 07, 2009
  • joecoolvette
    joecoolvette Aug 07, 2009
    Wanted to add;
    I realize the above may look a little complicated, but it isn't. I detail out too much sometimes, in providing a solution.
    In case you Cannot download the Zip file, or have trouble opening it, I thought I would give you the Pinout of JFP1 and JFP2 headers.
    JFP1:
    Goes up, and down vertically, and is on the bottom right side of the motherboard.
    2 pins going down in 5 rows. This makes 10 pins. There is NO pin on the Upper Left corner.
    Starting at the Top on the Left side, and going down,
    Pin 10, (NO Pin), pin 8, pin 6, pin 4, and pin 2.
    Starting at the Top on the Right side, and going down,
    Pin 9, pin7, pin 5, pin 3, and pin 1.
    Pins 8 and 6 are for the Power On switch. The + (Positive) goes to Pin 6.
    Pins 4 and 2 are for the Power LED light. (Use this header, if your Power On light has a connector for 2 pins)
    Pins 7 and 5 are for the Reset switch.
    Pins 3 and 1 are for the HarDDrive Activity light. This is the light that tells you when your harddrive is active. (HDD)
    JFP2: Goes horizontal across the bottom of the motherboard. It has FOUR rows of 2 pins. Looking along the Bottom, from Left to Right, there are 3 pins, then NO pin.
    ->I was mistaken with the previous information before. The JFP2 header has FOUR rows of TWO pins!
    Pinout going along the Top, from Left to Right,
    Pin 2, pin 4, pin 6, and pin 8.
    Going along the Bottom, from Left to Right,
    Pin 1, pin 3, pin 5, and pin 7.
    Pins 2, 4, 6, and 8 are to connect the internal speaker, if there is one. The speaker is used to hear the BIOS Beep Codes.
    Pins 1, 3, and 5 are used if you have a Power LED has a connector for three pins.
    There is NO pin 7.
6ya staff
SOURCE:
My letf headlight
Have you tried to clean and replace the ground wire/cable? That will usually solve the problem. If that doesn't work look at the pigtail where the bulb is plugged into. Hope it helps.
Mar 21, 2013 | 1993 Mercedes-Benz 190
Removal of alternator
3.1L Engine
  1. Disconnect the negative battery cable.
  2. Remove the serpentine belt from the alternator pulley
  3. Remove the air cleaner assembly
  4. Disconnect the positive lead at the alternator by removing the nut
  5. Disconnect the electrical connector (PLIS) plug
  6. Remove the bolt (#1) connecting the rear brace to the generator
  7. LOOSEN the bolt (#7)retaining the rear brace to the exhaust manifold, (it is not necessary to remove it) move the brace aside.
  8. Remove the remaining alternator mounting bolts and remove the alternator.
Jun 13, 2011 | 1992 Oldsmobile Silhouette
Hi there, I turned my ipod touch on to sleep mode and now I can't turn it on or off
Press the power button for a few seconds and it should starts
If nor maybe hasnt battery letf connect to your PC to charge an turn it on
Mar 26, 2011 | Apple iPod touch
Is it possible to reset a motherboard?
you can reset motherboard bios & back to its default settings by jumpering the CMOS battery terminal.BE SURE TO TURN OFF PC OR DETTACH POWER CABLE IN DOING THIS STEPS.
all u have to do is take out your cmos battery that is located in your motherboard & jumper the positive & negative terminal of the cmos battery by using a metal like screw.make sure your PC is not turned on or pull out the power cable of the cpu to avoid damage to the motherboard.
some mother boards have pins to reset its motherboard bios. just transfer the jumper to its reset location commonly it has only 3 pins.
Jan 29, 2011 | IBM 6574 PC 300GL 61H2470 (61H2646)...
If I switch off my Acer all in one computer for long time, when I turn on again, It does not turn on. All can see on my computer screen is on center of the screen is : Acer empowering people. And at the...
If the machine is OLD, check if it has a backup battery that might be depleted. Beyond that I would suspect the power supply may have a problem with the power-on-reset circuit.
Jan 12, 2011 | Acer Aspire T310 PC Desktop
How can you reset the cmos password
Dell Optiplex 780, user forgot BIOS master password (which is necessary to change the boot order to run BartPE from CD and do an image backup).
There is a jumper on the mainboard called PSWD1, which is set (shorted). Remove power cable from PC (CMOS battery can stay in place), open the lid. Remove jumper from PSWD1. Reconnect power, start the PC, hit F2 to enter BIOS. All passwords should be reset.
Leave BIOS, power off the PC, remove power cable. Reattach jumper to PSWD1, close lid, reattach power cable. Start PC. Enjoy.
Nov 11, 2010 | Dell OptiPlex 780 MT PC Desktop
Mi computadora tiene virus y mis programas no sirben como le puedo aser para que me la cambien mi internet explorer nome funsiona bien
Yo Se coma va. Pudes garra gratis programas que no questa dinero. La computadora se habre?
Si? Entonses vaya aqui.
www.trendmicro.com. Pudes mira e se tas infectadia..
se yama Housecall. Mira que pasa. Lo que se esta mirando, sone virusus
Pudes, limpia con los gratis programa de cómputo abajo.
AVG-AVG Anti-Virus Free Edition 7.5.519-
http://www.free.avg.com
Avast -
http://www.avast.com/
& How about Spybot -Spybot - Search & Destroy 1.5.2
http://www.download.com/spybot-search-de...
gratis from the WEB.
Ye se quedes paga, pudes compar abajo. El numbre es Kaspersky. Es muy bien. www.kaspersky.com.
Esta listo en PC Magazine.
If all fails, the best thing to do is Reformat. But remember, you will loose everthing, so save your documents and music and pictures, etc.
All 3rd party software will have to be installed, all over again.
Good Luck,
Hope
Nov 12, 2009 | HP Pavilion dv9000z Notebook
Nokia 6300 Unlock Code
I have a Nokia 6300 RM 217 IMEI 356832028870984 and i have forgot my security code plis help me reset it.
Jun 10, 2009 | Nokia 6300 Cellular Phone
Power Problems
You may have jarred a component loose inside. Open the side panel and carefully inspect the cable connections and circuit boards.
Check the memory sticks as well. Good luck!
Mar 13, 2009 | Gateway 310 Series (158920) PC Desktop
MSI K9N6SGM-V Motherboard Logo
792 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
