you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockarena.com/motorola-motorazr-maxx-v3/rs13wp9/
Sound like your sim card is faulty and needs to be replaced. Or you can try pulling out the battery and removing the sim card and leave them out for 2 hours and then reinsert the sim card and then the battery. I have the same phone and it is from Indonesia but works fine.
Remove the back cover, battery and SIM card. Wipe the SIM and the pins where the SIM card is inserted with a cloth if u can. Reinsert simcard, battery and back cover.
if you havent already, try to remove the sim and the battery and reinsert it.....if it still doesnt work, put your sim in another handset. if the issue follows the sim, the sim will need to be replaced. if the problem stays with the phone, attempt a master clear if the handset will let you. (the master clear will reset all phone settings and delete all your info so beware)
go to MENU > SETTINGS > INITIAL SETUP > select MASTER CLEAR
***security code by default is 000000 (6 zeros)***
u cud change the settings to modem...assuming that uv tried it u cud try a reset...
try holding down the power remove the back cover and battery (at this point briefly let up on the power) remove the sim card wait for "insert sim card" message remove battery reinsert sim card and battery release power key when the splash screen comes up
hope this helps
Thanks for using Fixya!
tc
if this dose not work you may need to reflash your phone
