How to use wet
SOURCE: lost instructions
You can click on the link below. Get the one with USA or E for English
SH02SH03SH04SH08&frmTyp=subgrp">http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=ui&s=8985&seite=&sString=5649|SH|SH01|S|360%C2%B0+Complete%2C+Series+5&subgrp=360°%20Complete%20-%208000%20series,%20Series%205&grp=SH01<|>SH02<|>SH03<|>SH04<|>SH08<|>&frmTyp=subgrp
SOURCE: disassembly instructions
To disassemble the 8000 Series shaver. Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic. The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece. There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries. This would also be a good time to clean the goo buildup from around the shaver head. Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer in placed in its proper hole, or it won't extend. A good place for parts, http://shaveroutlet.com/.
SOURCE: Where can I get a manual for Braun 8985 shaver
Found a Braun toll free phone number and they assisted.
SOURCE: suddenly,the trimmer blade of my braun 8985 shaver
If you've used the shaver for a very long time, it could be that the trimmer part has worn out. You can buy a replacement body for your 8985 that includes the trimmer, from shaveroutlet.com. Replacement is not very difficult (not soldering involved). You pull off the bottom plug socket, take off the sides, unscrew 4 torx screws on the body, and the shaver comes apart. Good luck!
SOURCE: Is it possible to replace the batteries in a Braun
Yes. You will find the correct battery type at shaveroutlet.com. See link below. You will need two batteries
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
I suggest that you read the installation tip on the item page
You will also find a helpful video showing how to disassemb;e the shaver at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
