I accidentally pulled out the lubricating strip under the bobbin thinking it was a piece of fluff when clearing a nesting problem.
I poked it back in with an open paperclip, will this be OK do you think?
I've done the same thing with my Janome 1600, I took it to the service man and he replaced the "wick" for me and gave it a service at the same time.
Your replacement of the wick is probably okay but if your machine hasn't had a service in the past 2 years then consider taking it to be serviced and ask the mechanic to replace the wick for you. If you leave it, then apply some oil to the wick, clear sewing machine oil or Triflow is good.
It should be make sure nothing is in way of operation of bobbin lubricate with silicon oil!! Good Luck!!!
Bobbin Winding
1 Put spool of thread on spool pin.
] Use spool cushion when using cross
wound thread.
] Use spool cap when using parallelwound
thread.
2 Lift thread guide bar all the way up,
and run thread through triangular
thread guide as shown in drawing.
3Run thread through bobbin winding
4 Run thread through top thread notch
1, and align bottom thread notch 2
with guide pin on bobbin winder
shaft.
5 Press bobbin stop up against empty
bobbin. If the bobbin stop does not
slide easily between the top and bottom
of the bobbin, check that the bobbin
is seated properly with the guide
pin (4) inserted into the lower notch
6 While holding the end of the thread, step on
the foot controller for a few seconds. Once
enough thread has wound itself around the
bobbin to hold itself in place, release the
foot controller and trim the excess thread.
7 Stop winding when bobbin
Begin
8 Manually move bobbin stop back to
original position.
9 Cut thread and remove bobbin.
bobbin insertion
1 Lift slide plate (and open bobbin
door).
2 Put bobbin into the bobbin case.
] Run thread through thread notch and
under latch spring, so that a length of
about 10 cm is exposed.
] Use a bobbin case with an idling prevention
spring.
3 Pull the latch lever of the bobbin case
out and push the bobbin case into the
shuttle race and release the latch lever.
] If the latch lever is not all the way on
the hook, it may fly off during sewing
and cause lower thread breakage.
4 Lower slide plate and close bobbin
door, following numbers 1 2 above
in order.
7 Stop winding when bobbin is full.
Take foot off foot controller.
* Place the thread end so that it
does not protrude from the bobbin.
Bobbin Stop
so this will be ok and no need to worry about this
I am not talking about winding the bobbin, so I don't understand your reply.
By the way, I don't know how I managed to get my question under Futura CE200 as mine is a CE-350. Sorry about the confusion.
